T8611 Datasheet
T8611 - The T8611 is a simple, high voltage, linear current regulator.
T8611
Taiwan Memory Technology (TMT)
T8611 и другие
0015286101
4.20mm (.165") Pitch Mini-Fit BMI Header, Dual Row, Vertical, with Snap-in Plastic Peg PCB Lock, 10 Circuits, PA Polyamide Nylon 6/6, UL 94V-2
0015286102
4.20mm (.165") Pitch Mini-Fit BMI Header, Dual Row, Vertical, with Snap-in Plastic Peg PCB Lock, 10 Circuits, PA Polyamide Nylon 6/6, UL 94V-0
0015286141
4.20mm (.165") Pitch Mini-Fit BMI Header, Dual Row, Vertical, with Snap-in Plastic Peg PCB Lock, 14 Circuits, PA Polyamide Nylon 6/6, UL 94V-2
0015286142
4.20mm (.165") Pitch Mini-Fit BMI Header, Dual Row, Vertical, with Snap-in Plastic Peg PCB Lock, 14 Circuits, PA Polyamide Nylon 6/6, UL 94V-0, Select Gold (Au)
0015286181
4.20mm (.165") Pitch Mini-Fit BMI Header, Dual Row, Vertical, with Snap-in Plastic Peg PCB Lock, 18 Circuits, PA Polyamide Nylon 6/6, UL 94V-2
0015286182
4.20mm (.165") Pitch Mini-Fit BMI Header, Dual Row, Vertical, with Snap-in Plastic Peg PCB Lock, 18 Circuits, PA Polyamide Nylon 6/6, UL 94V-0
0022286100
2.54mm (.100") Pitch KK Header, Breakaway, Right Angle, 10 Circuits, Tin (Sn) Plating
0022286101
2.54mm (.100") Pitch KK^ Header, Breakaway, Right Angle, 10 Circuits, Tin (Sn) Plating, Mating Pin Length 10.29mm (.405")
0022286103
2.54mm (.100") Pitch KK^ Header, Breakaway, Right Angle, 10 Circuits, 0.38lm (15l") Gold (Au) Selective Plating, Mating Pin Length 10.29mm (.405")
0022286104
2.54mm (.100") Pitch KK^ Header, Breakaway, Right Angle, 10 Circuits, 0.76lm (30l") Gold (Au) Selective Plating, Mating Pin Length 9.17mm (.361")
