T1133 Datasheet
T1133 - TRIANGULAR TYPE
T1133
TRIANGULAR TYPE
T1133 и другие
0002-06-1132
1.57mm (.062") Diameter, Standard .062" Pin and Socket Crimp Terminal, Series 1855, Female, with 0.38lm (15l") Gold (Au) Plated Brass Contact, 24-30 AWG, Bag
0002-06-1132-C
0002061131
1.57mm (.062") Diameter, Standard .062" Pin and Socket Crimp Terminal, Series 1855,Female, with Tin (Sn) Plated Brass Contact, 24-30 AWG, Reel
0002061132-C
0008500113
KK^ Crimp Terminal, 22-30 AWG, Hot Tin (Sn) Dip, Nickel (Ni) Under Plating
0008520113
Trifurcon Crimp Terminal 6838, 18-20 AWG, Bag, Phosphor Bronze Tin (Sn)
0009061130
3.96mm (.156") KK^ IDT Trifurcon Contact, 13 Circuits, Tin (Sn), Feed-To, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009071139
3.96mm (.156") KK^ IDT Trifurcon Contact, 13 Circuits, Tin (Sn), Feed-Through, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009481134
3.96mm (.156") Pitch KK^ PC Board Connector, Right Angle, Polyester Connector, 5.0lm (200l") Tin (Sn), 13 Circuits
0009508113
3.96mm (.156") Pitch KK^ Crimp Terminal Housing, Friction Ramp, 11 Circuits
