T222-25 Datasheet
T222-25 - Phase Control Thyristors, 25A
T222-25
Naina Semiconductor ltd. (NAINA)
T222-25 и другие
0011-40-2222
Terminator Die
001140-2222
Terminator Die
0011402222
Terminator Die
0014562222
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version G, Positive Lock, Wire Size 24, 0.38lm (15l") Gold (Au)
0022022225
2.54mm (.100) Pitch KK^ PC Board Connector, Top Entry, with Cat Ear Terminal, 2.54lm (100l) Tin (Sn), 22 Circuits, With Hooks
0022112222
2.54mm (.100) Pitch KK^ Solid Header, Vertical, with Friction Lock, 22 Circuits, Gold (Au) Plating
0022122221
2.54mm (.100) Pitch KK^ Wire-to-Board Header, Single Row, Right Angle, 22 Circuits, PA Polyamide Nylon, Gold (Au) Plating
0022122224
2.54mm (.100) Pitch KK^ Solid Header, Right Angle, with Friction Lock, 22 Circuits, 0.51lm (20l) Gold (Au) Plating
0022162222
2.54mm (.100) Pitch KK^ PC Board Connector, Right Angle, End-to-End Stackable, 0.80lm (30l) Gold (Au), 22 Circuits
0022172222
2.54mm (.100) Pitch KK^ PC Board Connector, Bottom Entry, 0.50lm (20l) Gold (Au), 22 Circuits
