T5100080 Datasheet
T5100080 и другие
0705510008 | 2.54mm (.100") Pitch SL Header, Single Row, Right Angle, .120" Pocket, Shroudedwith Beveled Plastic Peg, 9 Circuits, Tin (Sn) Plating |
0712510008 | 1.27mm (.050") Pitch DIMM Socket, Vertical, Multiple Keys, Plastic Peg, 168 Circuits5.0V Standard DRAM |
70551-0008 | 2.54mm (.100") Pitch SL Header, Single Row, Right Angle, .120" Pocket, Shroudedwith Beveled Plastic Peg, 9 Circuits, Tin (Sn) Plating |
71251-0008 | 1.27mm (.050") Pitch DIMM Socket, Vertical, Multiple Keys, Plastic Peg, 168 Circuits5.0V Standard DRAM |
71851-0008 | SL Crimp Terminal, Series 71851, Female, with 0.76lm (30l) Selective Gold (Au) Plated Contact, 24-30 AWG, Reel |
AD5100_08 | System Management IC with Programmable Quad Voltage Monitoring and Supervisory Functions |
Analog Devices |
CY25100_08 | Field and Factory-Programmable Spread Spectrum Clock Generator for EMI Reduction |
Cypress Semiconductor |
HEDS-6510-008 | Large Diameter (56 mm), Housed Two and Three Channel Optical Enco |
Agilent |
JM38510/00801BCA | HEX INVERTER BUFFERS/DRIVERS WITH OPEN-COLLECTOR HIGH-VOLTAGE OUTPUTS |
Texas Instruments |
JM38510/00801BDA | HEX INVERTER BUFFERS/DRIVERS WITH OPEN-COLLECTOR HIGH-VOLTAGE OUTPUTS |
Texas Instruments |
