T6421 Datasheet
T6421 и другие
0010897642 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 64 Circuits, 0.38lm (15l") Gold (Au) Selective Plating, Tin (Sn) PC TailPlating, 2.72mm (.107") PC Tail |
0014564200 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 20 Circuits |
0014564201 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 20 Circuits |
0014564202 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 20 Circuits |
0014564203 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version D, Back Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 20 Circuits |
0014564204 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 28, 0.76lm (30l") Gold (Au), 20 Circuits |
0014564205 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 28, 0.76lm (30l") Gold (Au), 20 Circuits |
0014564210 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version C, Front Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 21 Circuits |
0014564212 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 21 Circuits |
0014564213 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version D, Back Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 21 Circuits |
