T2297 Datasheet
T2297 и другие
0009-01-6229 | EDGE CARD CONNECTOR (3.96))/1.56 CENTER CRIMP TYPE - 2574 SERIES |
000901-6229 | EDGE CARD CONNECTOR (3.96))/1.56 CENTER CRIMP TYPE - 2574 SERIES |
0009016229 | EDGE CARD CONNECTOR (3.96))/1.56 CENTER CRIMP TYPE - 2574 SERIES |
0014563229 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 28, 0.38lm (15l") Gold (Au), 22 Circuits |
0014566229 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version A, Nonpolarized, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb),22 Circuits |
0014567229 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly |
0014600229 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 26, 3.81lm (150l") Tin/Lead (SnPb) |
0015388229 | 2.54mm (.100") C-Grid SL Single Row, Female, Version D Receptacle, 22 Circuits |
0015800229 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole without Peg, Dual Row, Vertical, Shrouded, High Temperature, 22 Circuits, 0.38lm (15l) Gold, (Au) Selective Plating |
0015915229 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
